Monitor Stand or Mount halp
Saki630
I've had my U2711 for 5 years and its about time I get a monitor mount. I feel that a Wall mount would be more secure than a desk mount.
I know nothing about these and I find that Ergotron is very reputable and NewEgg has this for sale. http://www.newegg.com/Product/Product.aspx?Item=N82E16824994064
I'm assuming my Monitor is less than 20lbs without the stand which is perfect. If I get a 2nd monitor like the 144hz Acer or Asus IPS would I make a mistake buying two arms?
What are your recommendations on my stand options or any guidance as to what to avoid.
if your monitor is less than 20lbs, why do you feel you need a wall mount? desk mounts are far easier to deal with
I prefer desk mount arms because you can move them precisely where needed as with the wall the studs may be not in right place.
Is Ergotron the brand I should be going with? Or should I look at others?
I can try desk mounts I guess as well.
Ergotron and ergotech are awesome. My ergotech easily supports displays well over their suggested weight limits without sagging or strain and for great price.
