wasteomind
- Aug 13, 2004
Hey guys,
I have a Dell 2407WFP 24" LCD monitor. I've had it for a number of months now and after a lot of visual testing I'm still a bit unsure of the answer to the following question.
Because the monitor's native resolution is 1920x1200, running at resolutions different from the native resolution will cause degredation of the monitor's image quality.
This is completely apparent when the monitor is run in lower resolutions using the "Fit to screen" or "aspect" options, which will stretch or scale the image to use as much as the monitor as possible. Using this method just does not look as nice as the native which is to be expected.
Running the monitor in 1:1 mode causes a visual tear across the screen usually directly across the middle of the screen, or in the lower 1/3 of the screen. No vsync options I have used have been successful in removing this effect.
Now this is what I am wondering. Since the monitor's native resolution is 1920x1200, when the monitor is displaying 1920x1080 or 1600x1200 resolutions does the monitor suffer image quality penalties as it does in other modes?
I ask this because 1920x1080 keeps the image in horizontal aspect, and 1600x1200 keeps the monitor in vertical aspect.
My eye hasn't been able to detect much of a scaling or tearing effect, but perhaps there is something else I am missing?
