Monitor resolution question
ListedGuru
Can anyone tell me if my Acer Aspire X (core I3) desktop with Intel 2500 HD graphics can run a 27" WQHD monitor at it's full resolution via HDMI? I'm not sure which version of HDMI my acer has (is there a way to check this)? I think it might need to be v1.4?
I really don't want to add a graphics card if if I can run a 27" WQHD at full resolution via HDMI. I'm not a gamer so just need it to work for general office stuff.
Thanks,
-Guru
Does your Acer only have HDMI? If it has DVI or DP then 1440p shouldn't be any issue. Even if HDMI doesn't work there are really cheap video cards under $50 that have the connections you need regardless.
