Monitor RE-calibration needed after only 45 days.
sblantipodi
Hi...
I'm using an Eizo S2433W with a DTP94b colorimeter.
Is it nornal that after 45 days my white point passed from 6500K to 6350K?
I needed to recalibrate the monitor to achieve the 6500k again.
Do you think that this is normal?
If it is a new monitor and a new colorimeter, maybe. Both probably require some time to break-in and stabilize.
unless you store the DTP94b is a sealed container with descant the moisture in the air will affect the filters over time and that color-meter is fairly old at this point so it's filters can be getting bad also a recalibration every 2 weeks is normal in places were the output has to be repeatable over time so 45 days seems kinda fast but it can happen plus 325 hours isn't long enough to really say it isn't the backight aging unless that monitor has color compensation built in.
If you haven't re-measured your display for 45 days, small changes in luminance or your colorimeter's filters stabilizing could result in such a change in color temperature. Going 45 days without calibrating is really a long time. I wouldn't really worry unless the same thing happens next month.
I disagree.
My panel was very stable for months and I am a heavy user(50+hours/week). It was several thousand hours before I measured a noticeable shift tint. Do make sure you panel is warmed up before calibration or measurements.
Try checking your White point at several locations on your screen. It is much more likely you will see that much shift from just changing the location of your probe than your panel tint changed in that short period of time.
why next month it should not happen? what will change?
thanks.
I disagree.
what colorimeter are you using?
the position where I put the colorimeter is always the same since icolor suggest me to put the device in the center of the screen.
PS: This monitor is completely new, bought 325hour ago (45days ago)...
I calibrated the monitor the same day it arrived home (after warming it up)
Do you think that this is the reason of the white shift?
I have an NEC SV monitor that came with an NEC branded Xrite i1 d2.
Even if they give you a target, it is likely a big one and you can move up/down/left/right some.
it's not big, the dtp94 fit perfectly in that target.
I would think that a day #1 calibration would probably shift after some hours of initial usage. (Have both NEC 24" and 30" SV models.) Even swings in room temperature can cause a slight shift.
regarding temperature we passed from 24°C to 30°C
is 50K a big shift from 6500K?
Now after about 25days from the last calibration (heavy usage, 8-10hours a day) monitor stands at 6450K.
is this normal?
The CCT tells very little because it doesn't describe one color but a range of colors. The behaviour of your screen (including repeatability regarding the colorimeter) is absolute normal.
Best regards
Denis
Best regards
Denis
Thanks for the reply Denis, always much appreciated.
I'm sorry for the ignorance but what is the CCT?
