I have an old Apple Powerbook G4 550Mhz with no screen and I want to use it with my Hyundai Image Quest L90D+. The Apple has a DVI port and my PC uses the DVI port. If I get a VGA to DVI converter and attach it to my Hyundai, will it work? I am 78.3% sure that my monitor has two inputs because in the menu there is an input section and you can switch between DVI and VGA.
And what adapter can I get?
