monitor question
Thurlow
Ok, let me see if I can explain the problem I'm having. You know when you switch the resolutions on XP, on a CRT monitor, when you move up to a larger resolution you have to press the buttons on your monitor and mess around with the Horziontal center, size, pincuishon, parallelogram...all those retarded settings. Well is there a program that will sort of just make it so that resolution fills up my whole monitor without me messing with all the settings? I'm going crazy here trying to make it so all the edges and shit are perfect.
Most likely what is happening is your video card changing refresh rates every time your resolution changes. I know the latest nvidia drivers let you manualy go in and change the refresh rates for all the resolutions you use (thats what I have to do with my old gateway monitor). What video card do you have???
Edit: I have mine all set to 60hz on everthing, so I can game at 1200x768. My monitor doesnt support anything higher :cool:
Get a better monitor. Pretty much all modern monitors have some sort of memory so that you only have to set the settings once for each resolution/refresh rate so that each time you switch resolutions it goes to whatever you set it for. Damn that was a horrible sentence. It is a monitor problem so there really isn't any software that will fix it.
