Monitor question
Thurlow
Ok, let me see if I can explain the problem I'm having. You know when you switch the resolutions on XP, on a CRT monitor, when you move up to a larger resolution you have to press the buttons on your monitor and mess around with the Horziontal center, size, pincuishon, parallelogram...all those retarded settings. Well is there a program that will sort of just make it so that resolution fills up my whole monitor without me messing with all the settings? I'm going crazy here trying to make it so all the edges and shit are perfect.
