Monitor pump and fan operation?
Thrust
I recently noticed my temps were unusually high only to discover that my fans on my radiator were not moving (poor molex connection) and once i had shutdowns due to high temps b/c my CPU loop pump had similar problems.
I read a review of this product from CoolIT that has an lcd showing temp, pump flow and fan operation.
http://www.overclockersclub.com/reviews/coolit_dominoalc/
the LCD is EXACTLY what I'm after (well, half of what I want b/c I've 2 water loops)
Does anyone know of something, anything similar to this? I just want the monitor capabilites, not the whole cooler itself. Would be so nice to look at one place and see that all my fans (I have 2 loops and a total of (8)80mm fans on my 2 radiators) and both my pumps are working by a simple visual inspection.
I monitor my 1 pump using Everest and a G15 keyboard since my desktop's under my desk. I have a scythe ace fan controller for fan monitoring as it has an audible alarm if fans stop spinning. You can also look into speedfan to automate events such as auto shutdown if pump fails/temps get too high.
