Monitor Problem - VX2025wm
Chris583
This problem started randomly, I have been using this monitor without a problem for a few years. Viewsonic 2025wm. Last January I formatted my desktop to Vista 64 bit and worked fine for the most part.
a few days ago the monitor wouldnt go on when i turned the desktop on. Than it would during startup screens and it would loose signal when login screen should come up.
I would be able to login if i unplug the DVI cable and plug it back in... than i found that it was a low resolution and that I could not make the display go higher than 1024x768
I have a nvidia 8800GT
My monitor is native 1680x1050, I've been looking on other forums and some people have the same problem... I have not been able to fix this after system restores, re-installing nvidia drivers and trying omega drivers. Safe mode, etc.
Right now I am on 1680res because there are no drivers but the default windows VGA ones. Generic non-pnp monitor on standard VGA graphics adapter.
I need drivers if I ever want to play games again on this computer but 1024 is too low a res to deal with on a widescreen monitor, i think drivers/monitor/gpu are the only things that can be the problem here. I don't know how this started cause I did not change or update anything, it just randomly happened one morning on bootup.
Any ideas?
You might not like this... but if all else fails then use VGA instead of DVI. Before you go and say it won't look as good, please try it out. This monitor looks excellent over VGA and you'll have trouble telling the difference.
