monitor power cycle => USB flash drive no longer recognized
Citizen Snips
I'm not sure if this thread would be more appropriate in this section or the Displays section.
I have a Dell 2408WFP monitor that has 4 USB ports. The USB uplink port on the monitor is connected to a USB port on my motherboard. I am running Vista Business 64 bit.
If I plug a USB flash drive into one of the monitor's USB ports while the monitor and the PC are both powered on, the USB drive is recognized correctly.
If I then leave the USB drive plugged into the monitor, turn the monitor off, and then turn it back on, the USB drive is no longer recognized. I see the drive letter associated with the USB drive in windows explorer, but the label I gave to the drive is not listed. Instead it just says the generic "Removable Disk". If I click on the USB drive in windows, I get a popup saying "you need to format the disk in drive G: before you can you can use it."
If I then unplug the USB drive and plug it back in again, it is correctly recognized, at least until I turn off the power to the monitor while the USB drive is still plugged in.
Any ideas as to why a USB drive plugged into my monitor's USB port is no longer recognized when I turn the monitor off and back on again?
This does not happen with any of the USB ports attached to my motherboard. That is, I can plug a USB flash drive into them, put the PC in sleep mode, wake it up, and the USB flash drive will be correctly recognized.
I'm thinking it has something to do with a power saving feature. I'd probably go into the advanced power settings in Windows and crank up all the options possible related to power saving. Also might go into Device Manager and find the USB Hub/Port that the drive is related to when plugged into the monitor and go into the Power Management Tab and disable any control by the OS.
Does a mouse have the same problem when connected thru the monitor's hub?
No. If I plug a mouse into the monitor's USB port, then put the computer in sleep mode, then wake it up again with the keyboard, the mouse works. I am even able to bring the computer out of sleep mode by clicking the mouse while it is plugged into the monitor.
OK, I just reformatted the USB drive and now it works with the monitor USB port. This is strange. If I don't post back assume the reformat resolved the problem.
