Hey all,
Need a bit of help. Today I'm picking up a 28" Hannspree HF-289HJB and currently own 2 20" BenQ FP202W displays. I am planning on using 1 BenQ for each side of the 28 inch monitor (oriented vertically).
Now here's my problem. What would you guys suggest for this setup? Any and all solutions need to be low budget. The lowest I've seen for a single mount is $32 and that's just a pole mount, no articulation to get the side monitors into position next to the 28 incher.
I know this is a stretch but any help you guys can give would be great. I've made the rounds through ebay and the other usual suspects.
Last note...the mounts can't be wall mounts. My apartment walls are not ideal for holding any amount of significant weight for any amount of time.
Thanks guys!
Thanks guys!
