Guys,
Does anyone know if a quality sturdy mount for three 27" displays, specifically the U2711? I just bought three of them to connect to my new system running an ATI 6990.
I do fabricate and metal work so an alternative is me simply bending some tube and cutting brackets on my CNC plasma table to fabricate various mounts. Anyone have any good links showing pictures of some decent designs? I don't need articulating arms and such. I want all three displays on a central axis for a wrap around effect at a common horizontal height. I would say only the outside two displays would need adjustment as anything other than vertical will put the bezels out of alignment, so it would simply be used for fine tuning. It would be a fun project however it may be more cost and time effective to buy something if it's available.
Thanks!
Thanks!
