SarverSystems
- Feb 9, 2002
So I have these 2 Viewsonic 21" P810's here. The wife says I can buy 2 19" widescreen LCDs (holding out for the Dell whatever's) if I can sell these to cover at least one of them.
The goal is to sell them both for enough to cover the cost of 1 1/2 of the LCDs.
So, in order to sell them for a lisghtly higher price, I was gonna mod them.
Both monitors work perfectly well, they just take up waaay too much space on my desk, and are a bear to take to LANs.
So, the modding begins.
So far, the list is this:
So what else can you guys think of? It's gotta be something with a purpose, or to make it look better than it does now.
I will be modding both monitors identically, except mayeb 1 will be blue and the other will be red, or something similar.
- Cut a large window into the top for a window. No fans or vents, just solid window.
- Cut a 80mm (or 120mm if I can) hole in each side for fans for cross-flow ventilation.
- Install LED fans.
- Wrap all visible wiring with split loom of the same color.
- Possibly install CCFLs, or LED meteor lights.
- Mod a card reader into the front bezel.
- Mod a USB hub into the front bezel.
- Swap out the green/yellow LED for a blue/something LED.
- paint the bezel from beige to black or 2-tone black/something.
- All 12V items will be powered off of soemthing 12V inside, or have a seperate power jack just for that purpose.
