Monitor Mayhem
Azphira
Ok, so my A90 is getting old, I decide to get a new monitor.
I go to bestbuy and pick up a Samsung 955DF. It has moire from hell that can't be adjusted out. Can't get the A90F+, Bestbuy here never orders it, they just have the display unit to taunt you.
So I return it and get an Envision EFT920 at staples, it looks like television lines from the center of the screen over to the left. I return it.
I order a P95f+B-2, it arrives looking like it was thrown off of a truck. It has vertical faint light blotchy lines in the center of the screen. FedEx returns it and the company sends a new one, box slammed in the front again just alot less.
The new one has the same blotchy lines just less intense, a 3mm geometric distortion, and 3 pin holes in the phosphor screen.
Viewsonic is paying to pick it up and sending me a new one, it will be a little while since it is out of stock at the warranty center.
So for now, I'm where I started, back on my old faithful A90.
Haven't had a problem with delivered monitors yet...
and I think I've been forced to use UPS, ick...
