A little more than a month ago, I put together my first computer. Brand new parts all of which I bought from Newegg:
Motherboard: GA-870A-UD3 AM3
Hard Drive: (First one out-right died after 5 days, RMA this one is working fine)Samsung Spinpoint F3
Video Card: XFX Radeon 5850
Processor: AMD Phenom II Quad Core 955 BE
RAM: G.Skill Ripjaw series (2x2GB) DDR3 1600, F3-12800CL9D-4GBRL
PSU: Corsair 650 W
OS: Windows 7 Professional
Monitor: ASUS VH232H Glossy Black 23"
The problem that has found me has been happening for about 3 weeks, or pretty much the entire time since Ive put together the parts. When I turn on the power button, the computer always starts up fine, with all fans and all drives making quiet sounds of a working system. The monitor however will only sometimes respond with the start up. What happens here is varied; sometimes my monitor will not recognize my system has started up immediately, and my display remains idle. I should mention here that I checked to see if it was a bad monitor, but it works with my laptop and TV. I dont think it is the monitor.
What happens most times I try starting up my system is that it will freeze sometime during either the initial BIOS screen, the Loading Operation System screen, the Windows startup screen, the login screen, or IMMEDIATELY after I log onto my system and then the monitor, keyboard, and mouse will go blank, but the computer will still be running normally. What happens the other 15% of the time is that my computer will start up just fine, and run normally with no problems anywhere.
So basically, I do eventually get my computer running after a few attempts, which isnt horrible, but it is inconvenient for me putting $1100 into this build. The kicker is thisfor the first time during running the computer during normal gaming usage, my monitor, keyboard, mouse all went blank and after about 10 seconds, I saw the computer restart. I CANNOT have this happening, so Ive finally decided to do something about it.
My monitor is plugged into DVI port in the back of my video card. There are no DVI or VGA plugs into my motherboard. In my video card, there are 2 slots for DVI cables, but plugging the monitor into either one of them gives me unresponsive problems in the monitor. Therefore I dont know if it is the video card, but I can play games at awesome speeds (Crysis at 35fps no problems).
So what Ive done so far to check and see what is causing this problem. Memtest86+ (4.0) and Prime95 have all passed with 0 errors and Ive run them both multiple times. Ive tried unplugging the power cord and holding in on/off button for 45 seconds, Ive tried taking an eraser to the RAM (this provided temporary relief as I was able to start everything up fine 5 times in a row), and Ive even tried messing with the timings and voltages in the BIOS. I can provide pictures if needed
I think the problems may be in incompatible RAM. My motherboard does NOT natively support DDR3 1600 RAM, only 1066, 1333, and 1866 (OC). Now, Ive heard on multiple boards that my computer should be able to just knock back the settings at 1333, but I dont know if that has happened successfully.
To anyone else willing to help a newbie builder out, I would most definitely appreciate it. I would much rather try and mess with bios instead of purchasing new RAM, but if I must I must. Up until messing with my BIOS settings, I have started my computer 2 times in a row without it messing up but for some reasons my underdeveloped computer savvy mind cannot comprehend, I feel that I have not seen the last of this problem.
PSU: Corsair 650 W
