Monitor help!!!
AMDXP
Ok well I adjusted my monitor size or screen size in cs and my screen gave me a video mode not supporeted, so i exit and now everytime i try to play i get the same message, How can I fix it!!!
I have a 1024x768 15" monitor and cs is set at like something way higher!!!
I tried uninstalling it and steam and resinstalling and that didnt work!
Much help would be a appreciated thanks!
Well, that setting is saved in one of two places.
Registry
OR
a config file in the CS folder
Find where that setting is at and change it manually.
If you can't find it, you will have to try uninstalling it again. This time when you uninstall, go in and manually delete the folder where it was installed. Also, clean out the Reg for any left over entries.
