Monitor Help: dual 20"/22" or one 24"
goleldar
I am so lost trying to find a monitor for my system. What do you guys recommend in terms of either a dual monitor setup using either 20" or 22" monitors or just one big 24" monitor. I read somewhere that 22" monitors use 6-bit panels. Is this very noticeable. I plan on using this system to do some video editing on. I don't want to spend more than $400 maybe $500.
Two of these would be great: http://www.directron.com/lcd2090uxibk.html
They are 1600*1200, so they are only 320 pixels narrower than a 24", while being the same pixel height.
It is an IPS monitor, and can be calibrated internally if you get a calibrater at some point in time.
I use it vertically next to my horizontal Dell 2007WFP (a 20" widescreen IPS 1680X1050).
For a 24"/26" IPS monitor, you'd need to spend at least $700.
dual monitors have its uses, but there are also some downsides... not as great when watching videos or playing games on your computer as you will either just use one small screen or it will show the same thing twice (split screen) instead of 24 inch which shows u a larger picture. duals do have positives for work, because u can have lots of programs or windows up as you have more screen room.
i think a good rule of thumb is if your using computer mostly for work then dual monitors hands down (or if you work while watching videos and like to multitask). If you are looking to use computer for games, videos, (anything that uses full screen) then a larger monitor works best.
considering that your asking the question, i'm betting you doing this for more screen space (work)... so go with 2 monitors.
Has anyone dealt with directon before? Do you know if NEC's limited warranty program is good?
I made this choice this winter, and decided to go with a 22" and a 20.1" monitor (Acer and Dell respectively). I primarily use my PC for gaming/browsing the internet, and I love being able to play a game on one monitor and switch over to the other to change music/ IM/ read/ ect. I cannot imagine going back to a single monitor solution. However as lee0539 stated, if you plan on only watching movies or just playing games, and large nice 24" would be the way to go.
I have only owned one NEC monitor, a 19" CRT, and had great luck with there warranty's and tech support, but that was quite some time ago.
I just got mine from Directron on Tuesday. Several others on these forums have received this monitor from Directron recently. Do a search of the forums.
The few people who have needed warranty service from NEC with another 20" refurb seemed to be very pleased with the service. You may want to contact NEC to confirm that the Monitor has a 1 year warranty .
A new 20" IPS monitor with a 3 year warranty and the ability to return costs $399 (Dell's 2007FP).
The NEC from Directron doesn't come with a DVI cable, so I'd recommend getting two of these DVI cables with your order.
i'm actually using a crappy 19 inch non widescreen monitor along with my 24 inch widescreen since i can still use two screens for internet browsing on 24 inch (just half each window). the 19inch or any size monitor works great for anything extra you want to do like music, walkthroughs, etc while gaming. However, most of the time I don't use the extra monitor and I put it aside. Even for work I can just use half screen for one thing (like internet/PDF) and other screen for word. But 2 monitors mean you have way more screen space for having multiple windows up. Anything you buy should always fit uses and not intrigue, go with what fits your needs.
