hello,
when i try to boot my computer into vista it will load all of the drivers (i have the text/diagnostic startup enabled), however when before i get into the login screen the monitor cuts off and goes into standby.
i figured it was a driver issue and try to boot into safe mode and the computer restarts every time it gets to the login screen.
at this point i think that it's a hardware issue with my 7950gx2 so boot into my XP partition that i use for games and everything works fine
back to the driver issue then, a system restore from the vista disk doesn't fix anything. the only solution i see is somehow deleting the drivers directly from the vista partition through my xp partition, then reinstalling them.
anyone else have any other solutions for my problem. the vista install is very new and i can reformat, but thats a last resort
thanks in advance
thanks in advance
