Monitor for Xbox 360 under $700
batbl18
Well after looking and reading and searching again and again I have come to the conclusion that many people are wondering what are the best LCDs for the both PC and Console Gaming. I have upped my budget to $700 after noticing some cool looking LCDs up to that price. I am not using this LCD for PC only for Console Gaming using my Xbox 360 and thats it. Now I've been looking at the popular 20 and 22 inch LCDs like the Dell 2007 Widescreen and the new Samsung along with all the other TN panels made by Chimei. I also then started looking at some LCD TV models id: 27 and 32 inch Westinghouse, and Olevia TV's. Now if I was to get a LCD Monitor I would be buying an external TV tuner so that I could watch television over it. Now I do not have HDTV however who knows in the future. I already have some Logitech Z5500 Speakers so I would love to use those with my setup. After initially looking at some nice LCD Monitors like the Dell and Samsung, I'm starting to think it may just be a better idea to spend just a bit more and get a bigger LCD which has a a Coax tuner built in.
So now I pose this question to those out there. What would you get for a display for an Xbox 360 and to watch TV and to use with a set of Logitech Z5500 speakers for a total price of around $700? This can be for example a 22 inch monitor and a VGA TV Tuner or a 27 inch LCD TV. I want the best quality picture even if it means sacrificing size. Thanks and post your opinions.:confused: :)
2407's are around 600-700..I think. And for TV if you have regular cable just use a vcr and plug the vcr into the 2407 via composite. If you wanted an hd tuner you could get a pinnacle usb (what I currently own) and it's great on hd.
So you think it's better to get a bigger computer LCD which i'm assuming has better contrast and colors than to get a bigger LCD TV? I'm assuming most LCD Monitors will have more contrast and better colors and look better than an LCD TV, correct?
