I'm posting for someone that can't register here. He's looking for a new monitor and I can't answer a few things.
Here's what he's looking for (I modified it some to be a little more clear):
-LCD at least 20 inches widescreen
-1080p input support over VGA to fully take advantage of the 1680*1050 resolution of the monitor with the HD-DVDs played from a 360
-Good quality overall
-$200-$300 budget
-HDCP for future use with the PS3
-And probably important to have aspect mode to keep 16:9 from filling to 16:10, so no distortion.
Anyway, I suggested these two at first:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824112007
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254020
Thing is, there are two things I can't answer.
Like all these 1080p supporting monitors, yes I know they are not 1080p, do they support over both VGA and DVI, or just DVI? It's important to know for Xbox 360 use. So once setup with a monitor that does over VGA and has an aspect mode to show 16:9 with bars, it will roughly equal 945p, much better than limiting yourself to 1360*768 over VGA.
2nd, They never clearly list the imaging modes on these monitors to know if there are all the modes like Fill, Aspect, and 1:1. The Aspect mode being important to know here. Suprising they don't list such a thing with all the new uses for HD consoles that are 16:9 instead of a 16:10
Here's the thread for this guy:
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=25645443&msg_id=288427750#288427750
I know this is asking for the perfect 20.1-22inch LCD monitor that does everything right, not leaving one option behind
Thanks
-$200-$300 budget
Thanks
