Hi guys,
I've an LG L226WT monitor that seems to be dying on me. During the past few days, every time the monitor goes into standby or is turned off, when it's turned back on, it's filled with a white screen. I already made sure it wasn't my computer. So far, the only way to fix it is by unplugging it, waiting a bit, and plugging it back in--using the power button doesn't seem to work.
Now, ideally, I'd like to fix this monitor as it works just fine otherwise. Does anyone have any ideas on how to repair it? Would a simple part replacement get rid of this issue?
Assuming repairing this monitor isn't worthwhile, what monitors should I look into that you guys recommend? Anything in the $200-$300 range would be ideal. Low response time is a must as I can't stand gaming on panels that lag like the majority of the HDTVs out there.
Thank you!
Thank you!
