Nov 29, 2008 #1 W widget54 n00b Joined Nov 28, 2008 Messages 4 need to buy a monitor say that the ips is the best so what do most us...thanks janis
Nov 29, 2008 #2 B Black Morty Rackham Supreme [H]ardness Joined Jan 8, 2004 Messages 4,728 Anything that isn't a TN panel will do fine. Basically, if it seems really cheap, it's usually a TN panel and YOU SHOULD NOT BUY A TN PANEL! One of the more expensive Dell monitors is usually a good buy.
