Monitor disabled
AMDXP
Hi, I set up my computer to use a TV for the monitor but it didnt work so I shut down and rebooted, now i cant use my normal LCD monitor. Is there anyway to fix this without reformatting!!!!! I really dont want to....
Do you get any kind of video on your lcd at all? Bios screen, windows logo?
Try booting into safe mode and changing the video resolution there.
If that doesn't fix it a dirty way is to boot into safe mode, uninstall your vid card driver and reboot so windows will go to the default driver (same one as safe mode) then install the real driver.
