Monitor crackling ...
IDF
Hasnt done it in an hour but an hour ago it was crackling and everytime it did you could see the screen flicker.
It was an expensive nec multisync 21 inch.
Wondering if i should get it repaired it it goes out or buy a new one.dunno if thes repair shops use quality parts.
If i get a new monitor will be no more then 19 inch cause on a budget.
Didnt expect this to happen at this moment but for the past hour it was not spiking every 15 seconds... grrrr :confused: :mad:
