Monitor "Courruption" at 1280*960 resolution?
Cali3350
Hello. I have an interesting problem with my Viewsonic A90f+. At a resolution of 1280*960 i appear to have curved lines at the edges of my screen. Easily visible in dark areas but i can see them over everything. At any other resolution this does not appear to be a problem. It looks like "waves" at the edges of the screen. Any ideas? I dont use the reolution much but id like it to work, considering thats standard.
Also, my Viewsonic monitor CANNOT align itself correctly, i have to do some serious tweaking to get it right. The image is NOT square, i must play with all settings, and its rather annoying, especially when i use a resolution i dont use much and must spend 30 minutes tweaking the screen just right. ANy ideas on that? It keeps settings once i enter them, but man is its normal way off.
Thanks!
