Dear [H]ardforumers
I have 2 monitors and very small PC table accomodating them. So, monitors stands take a lot of useful working space.
To get rid of stands I'm plannig to get monitor arm but here is the problem. My budget is X ammount of money. And I have 2 options to spend this budget:
1. To buy 2 single monitor arms - good ones from respectable manufacturer
2. To buy 1 double monitor arm - probably! good one from no name manufacturer
Question, what are the advantages and disadvantages of those 2 options? Do you see any?
I beleive 2 single monitor arms is a better solution since the load will be less on every single arm. From the other hand 2 arms will take a bit more space on the table and will look not as slick as 1 arm. So, do anypone have any opinions about what option is better?
