Monitor arm/extension?
cyclone3d
Anybody have any idea where I can get a monitor arm that can not only extend out to about 48", but also be able to swing up so it isn't hanging down at all?
We have a special application where i work and we need to mount a monitor overhead so it is out of the way, but be able to pull it down about 48" total and be able to swing it back up out of the way.
A ceiling mount that just has extension ability will not really work unless I can find one that has at least 3 segments. All the 2-segment ones I was able to find that go to about
48" have a minimum length of about 30" which will not work for us.
I suppose I coud get a heavy duty swivel arm as well as an extension and hook them together, but I kinda doubt that the swivel would be able to hold the weight and still hold up under normal use.
Think I may have found one that will work.
Originally i was looking for a celing mount one, but the only one that I was able to find that was anywhere close to what we needed is a whopping $1350. And vertical adjustment was still about 9" short of what we would have like to have.
http://www.lcdarms.com/products/LCD_Radial_Arms/9450.html
Found a wall mount one that should do the trick for a much better price af around $520 shipped.
http://www.lcdarms.com/products/LCD_Radial_Arms/9400-WM.html
Max extension from the wall is 68" :D
They are "medical" arms and both made by the same company so they should be really nice quality.
