Monitor Appears as HDTV - Screws up Resolution
Jarrstin
I'm having a problem. I have a Hannspree HF257 that, when connected with HDMI to DVI-D cable instead of the analog cable, ATI CCC reads it as an HDTV instead of a Digital Panel, thus fucking up resolution changes. Any way to force CCC to read it as a monitor? I've tried everything I can think of.
you could try to make windows see a different INF file for the TV, perhaps changing what CCC sees.
lets get a little more elaboration on How it messes up the resolution, what exactly is wrong with it?
Well what happens when it switches resolutions or goes to video mode in a game, to anything past 1680 x 1050, I get an "Out of Range" error on the monitor - even if the desktop was at 1920 x 1080 resolution. I've deduced it has to do with it being detected as an DTV, since my other monitors read as digital panels in CCC. It also only happens when it's not connected as an analog monitor, as then I don't have any problems.
Heres the deal - The Monitor has a native Resolution of 1650 x 1050 - to be honest, I think the only way you are getting the resolution of 1920 x 1080 on the desktop is through deinterlacing. anything above 1650 x 1050 IS out of range for the monitor and will not be displayed. You are going to have to be happy with 1650 x 1050 and some anti aliasing instead of turning up the resolution to get rid of the jaggys.
No, the monitor is the HF257PHB. It actually is supposed to support 1080P - 1920 x 1080 resolution.
Do you have the CD that came with your monitor? on it is the INF file you need. Under your Display properties under the settings tab click on Advanced, then click on the monitor tab and you will see the monitor type, if you click on properties that should bring up a different tab for the monitor, click on the driver tab, and then update driver and point it to the folder with the proper INF file for your monitor on the driver CD supplied with the monitor.
I've already done that, but CCC is still showing the monitor as an DTV instead of a Digital Panel.
You got me /shrug im outta ideas. - I would get in touch with the Hanspree Customer Service.
I used a program to read all this information directly from the monitor, now what do I have to do with it to get it to read as a Digital Panel instead of an DTV with CCC?
Monitor
Model name............... HF257
Manufacturer............. HannStar
Plug and Play ID......... HSD1A41
Serial number............ 903RG3NA02863
Manufacture date......... 2009, ISO week 3
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 540 x 300 mm (24.3 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.636 - Ry 0.336
Green chromaticity....... Gx 0.300 - Gy 0.616
Blue chromaticity........ Bx 0.138 - By 0.071
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 24-80kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 140MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 138.500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1920 x 1080p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1400 x 1050p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #4....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Detailed timing #5....... 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2448 2492 2640 1080 1116 1121 1125 +hsync +vsync
CE video data (timings supported)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1440 x 576p at 50Hz - DVD (16:9, 32:45)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
640 x 480p at 60Hz - Default (4:3, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... No
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 1110MHz
Report information
Date generated........... 3/18/2009
Software revision........ 2.30.0.793
Operating system......... 6.0.6001.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,22,64,41,1A,2F,0B,00,00,03,13,01,03,80,36,1E,78,EA,CF,55,A2,56,4C,9D,23,
12,50,54,BF,EF,80,D1,C0,B3,00,A9,40,95,00,90,40,81,80,81,40,71,4F,1A,36,80,A0,70,38,1F,40,30,20,
35,00,1F,31,21,00,00,1B,00,00,00,FC,00,48,46,32,35,37,0A,20,20,20,20,20,20,20,00,00,00,FD,00,38,
4B,18,50,0E,00,0A,20,20,20,20,20,20,00,00,00,FF,00,39,30,33,52,47,33,4E,41,30,32,38,36,33,01,27,
02,03,22,F1,4D,9F,14,13,12,1E,16,01,90,04,05,07,03,0E,23,09,07,07,83,01,00,00,67,03,0C,00,10,00,
28,DE,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,1F,31,21,00,00,18,01,1D,80,18,71,1C,16,20,58,2C,25,00,
1F,31,21,00,00,9E,02,3A,80,18,71,38,2D,40,58,2C,45,00,1F,31,21,00,00,1E,01,1D,80,D0,72,1C,16,20,
10,2C,25,80,1F,31,21,00,00,9E,02,3A,80,D0,72,38,2D,40,10,2C,45,80,1F,31,21,00,00,1E,00,00,00,31
Hmm, I have the 259 (previous model- only 1 hdmi port) from them and It has no issues as a generic PnP under vista 64. It defaulted to 1080i though. I manually set the properties to 1080P and it's in it's full glory.
Just wow is all I have to say.
Well I figured out what to do with the EDID, and it hasn't helped. So far I'm just going to run this thing on the VGA port til I can figure out WTF is going on. Side question - do you really lose enough from the quality from DVI to VGA? Maybe I can get some ease of mind knowing this.
VGA quality varies. It can approach DVI quality to the point that you can't tell the difference, or it can be so bad you can't stand it, or somewhere in between. DVI quality is either 100% or it doesn't work at all (which is why DVI is ultimately better). If the VGA quality looks good with no noticeable wavy lines or jittering, then run with it.
Having only HDMI and VGA ports (or even only an HDMI port) is one way to make a monitor or TV cheaper to make but not necessarily better, as you are finding out.
Well I ended up exchanging this damn monitor for an Acer H233H 23''. I'm not regretting it, though I miss the size a bit.
