Monitor advice for a newbie.
icondxm
Hi, i want to buy a new PC so i was looking at a new monitor between Samsung P2250 and 2233SW. The former is newer, TCO 05 certified, faster response time, looks better(IMO) but doesnt have HDMI. So which one should i buy, i dont own a PS3 or even plan to buy one, i dont watch blu ray movies but i will be using this monitor for playing games like MW2, GTA4, Crysis, and other games which will come out later this year. Thanks.
Hello.
Short story: Get the 2209WA.
Long story: Spend some time reading about why you should choose the 2209WA.
Looks really good but i dont think it's meant for gamers since it's an E-IPS panel and it's out of my budget which is around $180-200.
Ah TN, when will you stop corrupting the minds of all these little gamers out there.....
If he can't afford the cheapest non TN out there then TN is the only way to go....
Also looking at the Samsung P2250, Like the OP at twice (here in Australia atleast) the price the Dell 2209WA is a bit too expensive to consider.
