Moniter Spanning on 9700 Pro Possilble?
Falls Included
I'm happy & gay too
I know i can do it with the dets and my gf4, but my freind wants to use both his moniters and his 9700 pro for video editing, and i acnt find a spanning option for the life of me, any programs or reg hacks or anything out there for spanning??
thanks
EDIT: XP Home, 9700 Pro, 3.2 cats
Unless I'm missing something, if all you're looking to do is simple spanning that can just be enabled within Windows. Right click Desktop -> Properties -> Settings, then click on the monitor with the number 2 on it and check the box that says "Extend my Windows desktop onto this monitor." If you want special management options then use Hydravision or Ultramon but otherwise this will do it.
