Momentus XT questions
ob1
Just purchased one of these hybrid drives from Newegg for my son's laptop, since it only has a single drive bay. I have a few questions for those that have this drive out there, if you have the time...
Does the drive get recognized as a spinning disk by the OS and the SSD portion being transparent completely to the OS? Meaning, I won't have to turn off defrag and things like that for the drive right? If it is only seen as a spinning disk, a restore or clone from his current OS install would be fine then?
How does partitioning work on this type of drive? Like lets say I wanted to make a C partition for the OS and a D for games and such, does the SSD cache from each partition or only the C, or does it split the cache logically?
You should not have mess with any setting since the drive does not write directly to the 4GB SSD portion. I mean it uses the 4GB for a read cache and the controller decides what and when it puts items in the cache. In theory only the most used items will be put in the cache.
You only see the drive as 1 disk of the hard drive size. You have no control what gets put in the 4GB read cache.
Excellent, thank you for the response. I think we are going to back up his current setup, but try a fresh install and see how it goes.
Anyone have a link to the latest firmware and program to show the current firmware version for this drive?
