molex cables are 22 awg?
I believe PSU cables are generally 16 or 18 gauge. I would go with 16 if possible.
gauging should be marked on the wires. most ive seen are 18, some 16.
Are you going to crimp your own ATX connector ends? I need to know where to find those metal plugs for the 24 pin atx main motherboard connector !!!
I found them at Microcenter but they were literally .25 cents EACH. What a rip off. They didn't even sell the ATX crimper either. I asked all over the store and looked and I couldn't find anything. Yet they sold all the 24 pin connector bare plastic ends and 4, 6, 8 pin connectors in various UV reactive colors.
about 1/4 way down this page you can find thew waldom/molex crimp tool, which crimps all 3 types of psu pins - male molex, female molex and atx. it goes for $16.25 and also strips wire by guage from like 14 to 22 awg. you can also buy pins and connectors from there also, but buying them from performance pc or frozen pc might be easier.
http://www.action-electronics.com/molex.htm#Tool
