Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Just wondering what you've all found to be the best way to shape acrylic sheets. I've used Industrial dryers and torches before. Was never really fond of the torch but i'm looking for the best and cleanest way.
A notable link would be Boddaker over at GvL. He built his own acrylic vacuum forming table using heating elements from ovens. He even posted some videos of the process IIRC. http://www.gruntville.com/phpBB2/viewtopic.php?t=15519 (I don't know which page it's on, it's a huge worklog)
heat gun, but you have to very careful of surface crazing / burning.
Another method is to build a form of the shape you want, heat your acrylic sheet in your oven at a ~220F and plop it on your form and start working it. Re-heat on the form, if the whole thing will fit in the oven. Do NOT leave this unattended for any length of time. Keep a careful watch on it.
When I did CrossFlow first I used a torch and it worked fine. Than I used a Heatgun (like a HD hairdryer) and it worked too.
Remember dont use MAX settings. I had best results at med (550 watts). Its really not that hard. Get a couple of pieces and practice on them first. Go slow too and make sure you spread the heat (dont let it sit in 1 place too long)
Cool thing is if you mes up just re-heat it and bend it again.
