runLoganrun
- Jul 4, 2005
hI,
Currently I am using my Sager 8690 Laptop, w/ ati 5800 gpu and intel 840-qm quad core.
the optical bay has been replaced with a 2nd hdd.
Problem: BIOS no longer holds memory of settings, date, and time. it resets to default setup everytime it does not have power.
I have since replaced the CMOS battery, with no change... I did not test the battery beforehand, however it is a quality name battery and it would seem unlikely that it would be bad... also incidentally, it would seem unlikely that the original battery went bad, in under 2 years. One other issue which is possibly involved, although I dont see how, is that the main battery for powering the laptop is dead now also, I can leave it on a charger all night, and if it becomes unplugged it is lucky to make it past 5s of uptime, if any. My understanding is that the cmos battery is indepent of that system, and should still retain the settings, etc, with or without the battery
I have the latest BIOS and EP chip firmware flashed
Does anyone know what could be causing this?
Thanks so much,
rlr
Thanks so much,
rlr
