TeleFragger
- Nov 10, 2005
Ok so I know the Antec 900 isnt that highly desired here.... but I bought one of the ones on sale for $59.99
anywho... I got it in today... and let me tell you what... it is not constructed as good as my antec P180!!!!!
anyhow it seems ok and I am going to put in some parts (antec P180 is staying complete as a gaming server)
so
Antec 900 case will get
XFX 780i mobo (en route)
2x2gb ocz reaper memory (in garage)
q6600 (en route)
Corsair 620w (in garage)
asus sata dvd burner (in garage)
500gb sata ii hd (en route)
xfx 9600gt xxx edition (in garage)
so I have some time as 3 parts are on their way.
I searched here and didnt come up with that much... and on google... I found the following
1. Paint inside all black
2. use mirrored film on side panel
3. Cutouts to route cables in behind panel
4. reverse HD so cables tuck behind
5. water cooled stuff I have to transfer
what other options are there?
I saw in the p180 section someone had blue light memory... how does one do that?
so
#1. doesnt seem like worth it to me
#2. Ok maybe but not on my priority list
#3. This is a most definitely... I like the uuber clean look of cables routing behind mobo and all.. looks soooo clean!!!!
#4. Definite too... to get the #3 to work efficiently... and also power supply cables behind too....
#5. I have 2 bigwater se kits inside of my antec p180. I know thermaltakes have not been talked about too good.. I posted a while back that I got them for $40 a kit and they were open box... but turned out to be new!!! and complete!!!!!
so far 7 months and they are running great..
took my p4 3.0 (socket 478) from 61c to 25c
so far no maintenance also.....
I installed a second kit... and wired it all.. was getting ready to add it to my geforce 7950gt agp but didnt ever get to it....
so on this #5.... is where the other assistance is needed...
very top 5 1/4 will be sata burner
under that will be sata hd.. in the 3 1/2 to 5 1/4 converter
nothing in the next 5 1/4... so that is the top 3...
now lets start from the bottom
take a blank from the sata burner and install all the way on the bottom....
above that install the 2 water cool 5 1/4 thermaltake bigwater reserviors with pumps...
since that tripple drive tray is gone... I can take the 120mm fan and install it on the side of the case....
install the next tripple drive cage with fan back in...
so that isnt the hard part...
my concern is where do I install the 2 radiators with fans?
I figure watercool the q6600 with 1 of the kits...
water cool a 9600gt with the thermaltake vga block
when I buy a second 9600gt I will buy another thermaltake vga block...
but how should I hookup the water kits for 2 vga on 1 pump/rad kit?
also would it be a good idea for the video to run a reservoir inside the case? a big one where it would take alot of fluid to assist keeping the 2 cards cool???
so please bare with me on my liking thermaltake bigwater se kits.... but are they good enough for a q6600 and new 9600gt's????
Thanks
~Jeff
so
q6600 (en route)
so
Thanks
~Jeff
