Modify card bracket thing?
godofdeath
Hey if you do water cooling on the current day, using 2 brackets graphics card, can you modify it so that you end up using only one bracket?? Since the fan is gone and there's only the chip left, the other bracket isn't necessary. So is it possible?
Thanks
