Sep 17, 2005 #1 A AMDXP 2[H]4U Joined Jul 9, 2004 Messages 2,631 How would I install new Drivers for my LINKSYS BEFCMU10? I don't even know what version it is.... How would I find out? thanks...
Sep 17, 2005 #2 Y YeOldeStonecat [H]F Junkie Joined Jul 19, 2004 Messages 11,330 If you use an ethernet cable, you do not need drivers If you're using USB to connect, yes you'll need to install a driver. The modem didn't come with the usual Quick Setup Guide, and a cd-rom? To see which version you have, look on the sticker on the bottom. They are availalbe at http://www.linksys.com/servlet/Sate...835852&pagename=Linksys/Common/VisitorWrapper
Sep 17, 2005 #3 A AMDXP 2[H]4U Joined Jul 9, 2004 Messages 2,631 Well, it looks like I have the number 1 or 2 model... Its just after Comcasts new Upgrade to 6600 from 4400 I cant seem to get above 5.4-5.6 Mbps and Sometimes worse... although it says my modem supports up to 44 Mbps / 10 Mbps?
