model glue for stealthing my drives?
ToppDogg15
Would it be ok to use model glue for stealthing my drives? I want to make the drive cover as strong as possible and make it last for a long time. To me double stick foam tape just does'nt seem like it would be enough to ensure a long cover life.
Well, I can assure you, foam tape is very strong. I don't see why model glue wouldn't work for it, unless you used too much and it ate through the cover :p
i have used the double sided foam tape to stealth my drives and i must say that unless you plan on ripping off the bezel when u open the drives, then the tape should suffice quite well
Use the mounting tape. It's strong, but not permanent. There's no real reason to do it any other way, imo.
Model glue can permanently soften and mar plastic. It's a bad idea. If others have had good luck with the tape mentioned, use it. You'll actually have resale value on your old drives when you wish to replace them and you can use the drive bay covers again that way.
I'm using adhesive backed velcro tape. Works great, and no danger of misaligning the drive covers or gluing things together.
