Modding Tools
unc0ntr0l
What tools do you guys use to mod you cases and stuff? because i want to but some tools and I would love to know the price, and features of them.........:)
A rubber nipple, 2 pennies, toe nail clippers, a key ring, 4 girls ru paul-style barretts, a pair of milk caps, one nut, and a trojan.
there are a lot
dremel
jigsaw
hole saw
screwdrivers (variety)
exacto knife (depending)
files (from needle to regular)
soldering iron
needle nose pliars
and uhh
pretty much anything
I bought a:
Dremel
Sanding stick thing(the metal one)
Table Saw
Jigsaw and....
Lot'sa Lots of Pron :D :D :D
Standard can't live with out.
1. Dremel
2. Drill (18V) Cordless
3. Hair Dryer
4. Wire Snips
5. Percision Wire Striper
6. Percision Needle Nose Pliers
7. Jewlers tools (Screwdrivers)
8. Phillips, Sloted, and Standard Socket Screwdrivers
9. Soddering Kit (Iron, soder, stand etc).
Extras
1. Jigsaw
2. Hole saw bits
3. Mouse Sander
4. Sanding Block
5. File (and rasp)
6. Other Usefull tools
Materials
1. Lots of Screws, bolts and nuts
2. Heat Shrink
3. Connectors (Butt, Male and Female).
4. Zip Ties
5. Split loom, Wire Wrap, Cable Sleving (all of them).
These are just the basics, and most of them are really needed for a good job. What do you have in your tool box?
Cheers,
Well, let's see...
  1. Jeweler's screwdriver set (32 pcs)
  2. Electricians screwdrivers (12)
  3. Dremel plus 12343ß249 accessories
  4. an alanlog multimeter
  5. Jig, circular & hacksaw
  6. welding kit
  7. Cordless drill
  8. Corded drill, for hard work
  9. Leatherman Wave
  10. 14 pliers total
  11. Wire stripper
  12. Hole saw
  13. sander
  14. 100, 500, 800, 1000, 1500 and 2000 wet/dry sandpaper
  15. Electric sander (triangle type)
  16. Loads of other shit
    [/list=1]
    And for those custom heatsinks, we have a first-class machine shop at work, with shuch beauties as a laser cutter.
    MAterials:
    1. Sheet steel, 1&3mm
    2. screws. a lot of them
    3. rivets
    4. closed-cell foam
    5. Epoxy and normal glues
    6. Plexi, 5mm
    7. Wires by the ton
      [/list=1]
Are dremels that good? everybody loves them, what is so good about them? Do you finish faster with a dremel or do you make it look better?
Dremels are good for detail and small jobs. If your cutting a basic window, the Jigsaw will save your TONS of time. If your cutting elaborate windows then the dremel will fit more towards your artistic needs. As for fan holes, a Hole saw is the easiest, but they are a bit pricy. A dremel will cut a nice fan hole if you take your time and are careful.
add a 14" bandsaw and a Bridgeport vertical milling machine with assorted collets and bits for all applicaitons to the list :)
couldn't do 1/2 my stuff without those
lol nice
