Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I know there are several shops where you can buy PRE-modded components (doors, psu covers, etc), but the logistics of buying a part, shipping it back, modding, and shipping it back again mean that you end up with a lot of risk (plexiglass cracks if you *breathe* on it) and low profit margin.
You' seriously be willing to spend probably 50$+ to mod a 10$ case panel? Thats a fairly simple, cheap and fun mod to yourself. You need an electric drill, possibly a jigsaw if your plexiglass isn't precut, some edge trimming, and maybe a few designer nuts and bolts. voila.
unless you can buy a replacement side panel with a window for your case, you might as well just put a window in it yourself. its a relatively easy mod that you can do without spending an arm and a leg.
