Modding Macbook Pro: Difference between $100 bracket and $10 bracket?
adamvk
Question for you all:
I am going to be removing my optical drive and putting in a SSD as a replacement. I simply need a bracket to go in place of the optical drive, and I'm finding I can spend $100 on a "name brand" bracket, or buy a $10 one off of eBay? For something like a bracket, does quality matter? I feel like it shouldn't but better safe than sorry. I don't want to destroy a $500 SSD for whatever reason. Thanks!
This is a $100 example:
http://www.mcetech.com/optibay/
This is a $10 example:
http://www.ebay.com/itm/New-Second-...ge_Internal&hash=item2ebc293531#ht_3839wt_961
buy the $10 one, if it doesnt work buy another. if that doesnt work, buy the $100 one ;)
Ok, so it won't be an issue? Won't have slower data speeds or anything?
