Brother John
- Oct 30, 2012
Well I am sick of 1u 40mm jet engine fan noise so I needed a way to mount some stock AMD HSF's I have from updated comps to use but ran into that pesky problem of direct replacement.
I found some AMD K8 CPU Fan Mounting Brackets in China on fleabay for $2.50 w/free shipping.
They arrived in about a week but when I removed the stock HS I found a couple of problems:
1. CPU clamp release lever would hit the side of the frame before releasing.
2. Bracket had to be trimmed to clear the socket.
So off to work I go:
Trim off the excess plastic.
Bent the lever and mounted the bracket.
Snap on HSF.
Now just rinse and repeat 3 more times and my 4P will be ready.
Feel free to bash away.
Snap on HSF.
