Modding help for 2nd fan on vidcard!
I
infiniti029
Guest
Right now I have an extra 80mm fan leaning against the top retention bracket of my VGA Silencer rev3 on a 9800. I find with that extra fan on top I lower my vga temps 6-10F.
So what i'm trying to do is to figure out a way to mount my 80mm in a more permanent way.
1. Was thinking of somehow making something similar to http://store.yahoo.com/svcompucycle/zafbfanbras1.html, and have it blow across the side of the Radeon. Any idea on some kinda home-made version?
2. Somehow mount the 80mm directly on top of the Radeon, while still using the VGA Silencer on the bottom
I'd rather prefer #1 since cooling on its side will help cool the top and bottom of the card (mainly both sides of the memory). However, I don't have any holes in the side of my case, and don't plan on cutting it. So with a fan that close to the side of the case i'm not sure how effective that'd be.
you will probably have more luck putting this in the modding section where it belongs
Lol, believe me when I say I've ghetto modded a bit, so I can understand why you might want to do this rather than waste $7+s/h just for a thin peice of metal.
Well, the first thing I would check is, do you have a fan on the side of your case? If not, and you don't care if your PC looks like it got into a bad fight and lost -- like mine (you should have seen the other PC thoug! lol,) then cut a hole (or drill a LOT of little holes) over the area you want this and just put a fan in the side.
Anyway, the best ghetto solution I can think of for this is to find a peice of metal that it thin enough to be easily maleable with the help of a hammer and pliers, then cut holes and bend appropriately. This would be relatively easy since all you'd have to do is bend down one end of it and use the pliers or a cutting tool to get it the right shape to fit in a pci slot, then, bend the other end and drill holes to put screws through and attach a fan.
Failing that, I'm thinking you might be able to rig up something with plastic (like what you could cut off of some box or something.) You could easily drill the holes in that of course, and cutting wouldn't be an issue. I can't figure out how you could safely attach two peices together, so all I can think of is to carefully bend it with the help of something really hot (melt too much and it gets weak, but, melt just a tiny tiny bit while holding it slightly bent should make a very strong permanent bend.)
Lol, yep, I've played around a bit with ghetto solutions and my trusty blowtorch as well as my lovely drill and hammer (not so great pliers though. Nope, just plain old needlenose pliers -- er, ok, you drug it out of me, it's a cheap 12V drill. Happy?)
EDIT: Speaking of boxes, cardboard might kind of do though it would tend to move around a lot and could be a problem in that area. Maybe cut a small thin peice, screw it in to the back end of the fan and bend it so that it sticks out and keeps the fan at a small distance from the card or whatever.
Best ghetto solution by far, is a box-fan sitting next to your case with its side opened.
:p
Nazo!! How can you forget that ;p
Because I have a 4" big fan cut into the side blowing over the general area where my CPU, northbridge chip, and video card are which sounds like a tornado attacking several mach6 jets at once if I run it at FULL speed (it's 12V rated, I run it at 5 and it makes rather a bit of noise.) I have a switch that lets me run it at 7V in an emergency though. This thing has amazing CFM even at 5V though. You do know that CFM rises exponentially by the size of a fan? You can run a tiny 60MM thing at 7200RPM and not get a tiny peice of the CFM you get from a 120MM running at 2800RPM. d-: So really this thing is plenty. It's capable of probably more than two 80MM fans working together due to the exponential thing.
I didn't have room for the big fan on the desk since my computer is a few inches to the right of my mouse pad sitting on a little stand I built into my desk just for it. Besides, lots of EMI from that. This fan I got at radioshack before they started routinely selling 120MM fans for PCs and I just spliced in some connectors and plugged it into my PSU. ^_^ The advantage here being that it is DC and normally you can't find a large DC fan to set beside your case like that. I'm not sure why AC causes more EMI than DC. I'm sure it makes perfect sense, you just have to know more electronics than I do.
Nahh, I wasn't being literal. ;)
And to be honest, I've always been under the impression that larger fan + lower rpm > smaller fan + higher rpm. Even before I figured out the scientific reasoning behind it. :p
Why AC causes more emi than DC though, thats a good question. I'd like to know that too. if you find out before me, post :p
I'll google tomorrow while im work. heh.
I believe it's because of the changing occuring at a somewhat constant frequency. Electric pulses at about 60 times a second (or 50.) DC doesn't change but remains constant. In each case, we already are making an electro magnet to turn the fan, so we are definitely playing with EM fields here. Just one generates more than the other.
Either way, one has to be careful setting a fan like that too close to their PC. So it makes for a very terrible permanent solution. Also, if you ever want to carry your PC somewhere, you'll be a lot happier having something built into there more or less, even if it is ugly as sin (god I wish I had a digital camera so I could show you this monstrosity.) ^_^
Anyway, if it's a 12V DC fan, you MIGHT try something relatively large (make sure the wattage isn't TOO high though...) Just don't cut until after thorough testing because the larger they get, the worse the EMI around them is. A fan on the side IS a better overall solution to a side mounted thing inside the case though if you ask me. You see, the fan on the side pulls in ambient air, so is not as reliant on the chasis temperature. This tends to keep things a little bit cooler (and was the primary reason I originally had the fan situated closer to the memory back when I had really really crappy kingston valueram in a hot case.) I should point out that SOMETHING in all this ugly case mod I've done is working pretty well, because my chasis temperature is usually reported about 1 degree above whatever ambient temperature is. The worst I've seen was about 4 degrees above ambient. I still believe it was the side fan that was the most important detail (though I have tried to manage air-flow as well as possible.)
Something like this?
http://www.newegg.com/app/ViewProductDesc.asp?description=35-888-112&depa=9
Showimage.asp
I've seen those. There are only two problems with that. One, it might be able to kind of interfere with the built in fan, especially if you had it pulling the air instead of blowing. Two, it can't blow over both sides of the card, only one side, so it won't help the memory on the other side (and I haven't seen very many cards with chips only on one side since my Geforce 2 GTS -- in fact, my sister's Geforce 2 GTS-V a bit later had them on both even though it had the same amount of memory on it,) whereas the side fan should be able to get both if you line it up correctly without interfering with the HSF too much presumably (and hopefully helping in fact.) See, I'm worried that if you blow too directly towards the hsf with a larger fan, it will create a sort of pocket where the air kind of cycles in that one area instead of moving properly.
Oh yeah, and ghetto modding is cheaper -- my ways are often completely free in fact (ok, a large fan wouldn't be -- then again, a small fan MIGHT work for this purpose if you still put it on the side.) d-: Then again, such a setup might cool the chipset and cpu just a tiny bit more since it will get ambient air temperature a little more directly to the area perhaps.
Anyway, other than the part about both sides not being covered, in reality that's probably not such a bad solution. Not as much fun as a good ghetto mod where you have to cut and hammer at things, then stick tape everywhere though... Not as much fun at all. )-:
I was having lockup problems when I softmodded my 9800se.
I took a pci slot cover, drilled some holes, bent it a little and slapped a 80mm fan on it.
It's basically a poor man's Zalman bracket.
Works good for me though, haven't locked up since.
