Modding Flash Drive
Ang
Kind of a looks mod type thing.. and I know it's not a case but I don't know where else this would go:
So I'm into a lot of cartoons, and graphic design and stuff and a while ago I came across these flash drives of characters:
http://www.kidrobot.com/products2.cfm?ID=7388&cfid=11887897&cftoken=84207845&nav_chooser=
Like that.
except for 2GB that's really expensive and I would rather make my own character.
I plan on using this flash drive:
http://www.newegg.com/Product/Produ...lickDeals-_-NA-_-NA-_-NA&Item=N82E16820227333
But the only problem that arises to me is the fact that I never like extensively used a flashdrive except for external HD. And I was wondering do Flash Drives get hot? Do I have to worry about the flash drive failing if I encase it in vinyl/sculpey? Any insight?
Nope, there should be no worry about encasing your flash drive. I actually took a flash drive out of its case and embedded it in epoxy resin after it went through the wash (scared me to death!). I still use it today, with no issues.
don't worry about them, they should withstand pretty much anything.
the easiest method i have found to date is using polymer clay to enclose the flash drive with whatever shape you want.
then bake for 30mins and done.
ok, for the baking part i took out the electronics ...
Modding onto a drive would be somewhat easy but i once tried a housing replacement for mine and the case didnt survive.
