I'm looking for pictures of towers modded for 120mm fans. I'm trying to quiet down my system a bit (already using Zalman hsf for cpu and fanless for my gpu). I have 4 80mm fans (2 in the front and 2 in the back) on a reostat that has them running at I think ~5Volts. My TruBlue powersupply has 2 built in 80mm fans. There are also 2 fans built into the motherboard, but with the propper config in the Abit utilities I can run those fairly quietly. I really want to lay in some sound deadening and mod the case for 1 120mm in the front and 1 in the back. What kind of padding do you all use for sound deadening? I need to put something in front of the hole in the window (fan spot) too.
Any pictures or advice would be great. I looked alot into building a duct type system for cooling, but that's mainly for the cpu, which is being kept very cool by the Zalman HSF. Would ducting be a viable option for cooling my raid array and other storage drives while keeping the noise down?
