omegatotal
- Mar 15, 2002
+1
also u could do something a little different in regards to the panels on hinges..
i dont know where you were planning to hinge them, BUT you could instead use a locking system like some wooden file cab's use, but hidden away, and then use the same rails that they use on nicer drawers.. the BB closed slides that you slide out fully then press the small lever to release, (not the kind that you pull out and then lift, the kind that you can pull out and shake but it wont come off till you press the release)
that way instead of swinging out, you can just slide the entire side off, and even include the left and right face, leaving plenty of room to get in the side/front and access the lcd connections/cases behind, even while the entire "tv" is against a wall, and in close proximity to surrounding furniture.. OR this would be an option for the rack mount cases to be accessed/removed w/o moving the whole tv from its position..
basically the front fascia will be secured to the side "cosmetic" pieces, which will be trimmed to have rails on the in side top and inside bottom edge (as it were to sit if it was put together) you would have the locking system either somehow hidden in the front, or maybe under side, using a simple lever..
and to prevent any rigidity issues, you could use simple steel supports on the corners with triangle pieces and around the front/sides of the lcd, which could also allow you to make a mounting bracket out of some more steel tube/u-channel with a flat area to secure the lcd to, and just some minor felt padding on the edge of the front fascia to prevent any rattle and damage to the lcd..
another thought, getting the gas charged hood or hatch supports and using those to make the top open, you get the idea. And this could leave another form of access for simple wiring changes w/o having to move the beast of a loaded tv
