xDezor, I sure do. And it is really really close. About 5mm or less..:Looks great. Do you have a top view picture with the PSU installed so we can see just how much space there really is between the HSF and the PSU?
PixelsGC, You won't see the dvd from the front end once fully assembled. It has a faceplate that isn't on yet. And the dvd is set back behind this faceplate AND there is a slide-up door, so I don't think you'll be seeing thisI got an idea for you to make the front even look cleaner, make you optical drive a stealth drive. It would pull the front all together. Great work bro!
Flyinfinni, It's a 140mm Antec Tri-cool. The top fan is a 120mm of the same.Nice work. BTW- what size is that front intake fan?
wowza, that is a tight fit!
By the way, what motherboard did you end up choosing? Does placing both sticks of ram side by side pose any problems with regards to running dual channel? Or is that not an issue with current hardware?
Ha! Yeah... I've read the reviews. But it hasn't given me any problems and it's been running this setup for awhile now (just not in this case, obviously). I'm hoping it can hold out awhile longer. And if it does fail I hope it doesn't take any of my components with it. The latter seems unlikely. But I didn't want to hack up a brand new PSU without proving the idea first. Nor did I want to spend any money on this, haha.You're running that off a HuntKey? Holy crap, nuclear bomb waiting to happen...
amd dual channel configurations are 1+2 or 3+4, intel dual channel is 1+3 or 2+4. The person asking must be used to intel with their every other slot configurations
I see, that makes sense. Thanks.Depends on the ma manufacturer. Some want you to put ram in matched color slots (most) some want you to put them in alternating slots.
I've seen enough articles saying that running in dual v single channel with ram these days does not usually make an appreciable difference.
Thanks!
Does anyone have any ideas of why this think won't boot??? Like I said, everything is spinning, but nothing... I've removed the GPU, swapped out the GPU, removed the RAM, swapped out the RAM, swapped out SATA cables, etc. Other than swapping out the PSU I'm at a loss here.
Now that I think about it, I have had a similar issue in the past when the 4 pin P4 connector isn't seated. I'll have to check that when I get home. But any other ideas?
Does the PC start up without the 260GTX? Does the CPU fan turn on? That would eliminate the guesswork with regards to drawing too much power. Another thing to check would be whether that motherboard halts startup if the CPU fan is not connected. Is the aftermarket CPU fan plugged into the motherboard CPU fan header?
Pull everything out and set it up on a cardboard box or piece of wood. Might be a grounding issue.
Sorry, I was running late for class and must have missed it.Buried in the last few post you'll find your answers.
Yes, I have tried booting w/o the GPU. The CPU is spinning, as are all fans except the GPU's. The fan on the big shuriken is plugged into the cpu fan header.
