Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Not only will it void your warranty, but each key is individually lit which means you'll need around 101+ led lights. You'd probably be better off just getting the Dragon age II edition of the black widow ultimate which comes with red back lighting. The link is below if you'd like to check it out.
Buy Dragon Age ll version, swich outer plastic case with yours, send back your old keyboard disguised as DA ll version. Problem solved, seen at least one other person on here say they've done that.
if too much bad karma for you, then buy DA ll version and sell old one.
