Modding a 7000b on a shuttle sn41g2v3
Thermite Paste
Im installing a zalman 7000b on my shuttle, and i have ran into a slight problem. I put a p4 mounting bracket in there, and everything seems to be working fine, but the mounting tab on the heatsink hits my northbridge heatsink. pics:
(the mounting tab isnt aligned in this picture, but you get the picture :) )
So, my basic question is, can use a smaller heatsink on my shuttle northbridge without it overheating? one of the ones i have in mind is this:
If theres an easier way to get it to fit, like bending the mounting tab out of the way, then i'd rather do that. But as it is, even if i fix the mounting tab problem, the copper tabs of the heatsink still touch the nb heatsink, and i have to bend them to get it on:
(sorry for the white areas in some of them, i'm kinda in a hurry and have to use mspaint.)
Your stock NB cooler is active, so I would think that you would still need active cooling on it unless there is enough blow-over from the Zalman cooler.
You could get a passive Zalman NB cooler and cut it to a custom fit.
