Modded video driver for 6970 2gb? or help
the X
i play a game called Rappelz Epic 7.3 (US) and i'm getting full system freezes anywhere from 5 minutes to 2 hours into play. Someone in the Rappelz forums told me to re-install an older video driver so i went from version 11.11 to 11.6 and am still having the same issue. Is there a modded Catalyst Driver that would work better than using an older version?
I also play Battle Field 3 sometimes and don't have any issues in game at all.
heres other things I've tried so far to fix the issue i'm having on the Rappelz forums: http://rappelz-forum.gpotato.com/viewtopic.php?f=6&t=1002692&sid=12185049167edf937ffda9131ef90041
never played it but i'm guessing its an openGL game? if so then theres probably no way to fix it since they are probably running a legacy openGL engine which AMD dropped support for. but again thats if they are using the openGL engine, if they aren't then its a totally different problem.
